Top End Gaskets
Hello all,
Getting ready to do the Top End (2013) about 100 hrs. I plan to use OEM piston/Rings. I have seen a few top end gasket kits out there. Any recommendations?
Also If I decide to go with OEM Gaskets, do I need anything other than the Base/Head/Valve cover gaskets?
Anyone have good luck with the Wisco or Vertex complete top end Kit.
Thank you,
Mark
Pistons are all pretty good but I would only use oem gaskets.
You should only need base and head, valve cover doesn't really need to be replaced, you can always put a little bit of liquid gasket in the valleys but they never leak.
Edited by Rotaholic
