2011 450 dies when I crack the throttle
When the bike is in neutral or i have the clutch pulled in when i crack the throttle most of the time the engine dies. does it sometimes too when down shifting. ive tried raising the idel speed and that didnt help could it be a bad sparkplug?
Sounds like you need to check your tps
Tps is your throttle position sensor, it's on the side of the throttle body. Adjusted with a multi meter and a couple screws.
