Why no kx250 jetting database?
Why do we not have a jetting database like the Ktm guys ?
Or is there one ?
Is this something I should start?
Edited by kxrob
it seems to work for them as long as all relevant info is given
below is the template they use
Year:
Model (E,W,XC,M):
Carb size (38 or 36mm):
Slide:
Main jet:
Pilot Jet:
Air screw (turns out):
Needle model/Clip position:
Altitude where you ride:
Reeds:
Pipe/silencer:
Head mod:
Other mods:
Type of fuel:
Where in the powerband do you ride (Lugger - for technical stuff, or wide open - desert / MX):
Degree of satisfaction:
And finally: how much spooge 1) none, 2) little, 3) medium, 4) lots:
Notes:
Might want to add displacement onto the list. My 265cc kx runs alot smaller jets than a stock bore.
just out of curiousity is it smaller just on the pilot jet and starting taper of needle ?
would you like to put your info in the kx250 database i just started
Kx250
265cc
38mm keihin
Stock slide
150 main jet
42 pilot jet
Air screw 1.5 turns out
Stock needle 2nd clip
Altitude 1300ft
V force 3 reeds
Fmf fatty/pc 304 shorty
Stock head
93 octane 40:1
Woods/free ride
2, little spooge
is that main not to lean with a fatty pipe ?
No not at all. Larger displacement means it's going to pull more vacuum in turn pull more fuel. The bigger the bore the smaller your jetting gets. (Most People figure it'd be the opposite )
I've tried upping the main jet one size and I can get away with it in really cold weather but in normal riding weather it fouls a plug every ride.
