Please help yz 125
I have a 2000 yz 125 that won't start, i recently had the carb all cleaned and fixed, just yesterday the bike was starting in 2-4 kicks. I tried turning it on just so that i made sure everything was still ok and it wouldnt turn on. It makes the sound of a bike that will turn on when kicked but just won't turn on. Maybe the spark plug. The kickstart can be pushed down with one hand fairly easily. Please help idk what is wrong.
An engine needs: compression, fuel and spark to function.
If you think compression is decent, (even a low compression engine will start, but power will be low)
-is the spark plug wet or smell like gas ? (fuel getting to the combustion chamber)
-do you get a sufficiently strong spark when grounding the plug on the engine ?
Edited by mlatour
