kxrob
Kx 250 Jetting Database
Well i have decided that we should give this jetting database thing a go
so credit goes to GMOSS357 for the original template from the ktm side of the forums
i will start with mine and update when i improve it
Year:
Model : 2000 KX250
Displacement (cc): 250cc
Carb size (38 or 36mm): PWK38S (stock)
Slide: stock
Main jet: 158
Pilot Jet: 45
Air screw (turns out): 1 1/2 winter 1 3/4 summer
Needle model/Clip position: n3we (stock) 3rd position
Altitude where you ride: 0-500 ft
Temperature: winter ( 20 derees celsius (68 f) /summer 35 degrees celsius (95 f)
Reeds: v force 3
Pipe/silencer: fmf gnarly / fmf power core 2
Head mod: stock
Other mods: nil
Type of fuel: 95 octane (93 us grade i beleive) 40:1 castrol activ semi syn
Where in the powerband do you ride (Lugger - for technical stuff, or wide open - desert / MX): lugger/75% mid range
Degree of satisfaction: 80%
And finally: how much spooge 1) none, 2) little, 3) medium, 4) lots: 1 (none) but oil pipe tip
Notes:
next step is to drop pj to 42 and change needle to a suzuki needle (maybe nedj)
when i make the switch to 50:1 full synthetic
and repack silencer and clean out gnarly pipe
this is my pipe after last ride
Edited by kxrob
Posted Today, 03:08 PM
2001
Kx250
265cc
38mm keihin
Stock slide
150 main jet
42 pilot jet
Air screw 1.5 turns out
Stock needle 2nd clip
Altitude 1300ft
V force 3 reeds
Fmf fatty/pc 304 shorty
Stock head
93 octane 40:1
Woods/free ride
2, little spooge
Edited by kxrob
2000kx250
Pilot 52
Main 158
Air screw 1/12
Neddle stock N3WE clip 3rd position
Engine stock
Castrol R30 32/1
Best smelling bike at the track !!
Sea level - 500ft
Spooge.....yip
Fun to ride..... 🙂
Not at this stage. The bike has more than enough power and does not foul plugs. I'm not going to lean out the bike to chase a very small amount of power and will cash in on the rich running longdivity.
As I said in my last post....the bike has more than enough power. For me that is. So I'll get my "rideability" by getting the fork's and rear shock rebuilt.as they are all std.
UPDATE
Year: 2000
Model : KX250
Slide: stock (8)
Main jet: 158
Pilot Jet: 42
Needle model/Clip position: NECW Suzuki needle 3rd clip
Reeds: v force 3
Head mod: stock
Other mods: nil
Type of fuel: 95 octane (93 us grade i beleive) 40:1 castrol power 1 tts full synthetic
Degree of satisfaction: 95%
And finally: how much spooge 1) none, 2) little, 3) medium, 4) lots: 1 (none) pipe clean as
Notes:
pj now 42
Needle : necw
repacked silencer and cleaned out gnarly pipe
Edited by kxrob
calling all kx250 jetting experts  😉
thinking of raising clip on NECW needle to 2nd clip from 3rd clip
how does this compared to say a NECJ in 3rd clip position
The NECJ needle is 1 full step leaner on the starting diameter than the NECW, which effects up to just under 1/4 throttle. beyond about 1/4 throttle both needles are the same.
so i full clip ?
mine just seems a little bit flat of idle , so thinking it was a bit rich still
so i full clip ?
No, The clip heights between the 2 needles( NECW & NECJ) is the exact same. The starting diameter of the NECJ is slightly thicker, which makes it leaner. The next leaner needle in the Suzuki NExx series after the NECW would be an NEDJ, which is 1/2 clip position richer than the NECJ.
so if i want to lean it out with out buying a new needle and drop it down 1 clip (from 3rd to 2nd)
how would it compare to the NECJ  (leaner or richer running ) in the 1/4 throttle to 1/2 throttle range
With the NECJ in #3 and the NECW in #2 clip position, and between 1/4 and 1/2  throttle, the NECW should  be slightly leaner.
Ok
What is your take on it feeling a bit flat just off idle
Do you think it's rich ?
Ok
It's tough to tell without being there or listening to the bike. You're going to have to do some testing. Start by  lowering the needle, go from 3# clip position to #2 and see what difference that makes.
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
