Drz400
Do you guys feel that the drz has enough power? What are some mods that you have done or recommend. How's it wheelie?
I just picked up a DRZE. More than enough power for me. I used to own a KLX250. I was bored on it. It would go anywhere, but I was bored. The DRZ E is amazing to me in comparison! Mine has 3x3 and a slip on. Pretty much stock otherwise as far as power is concerned.
The E I picked up has 14/44 gearing.wheelies are super easy in first. It goes 50 like nothing. It needs tires and a chain so I havent been any faster. Its a bit taller and heavier than the KLX was but the POWER is WAY better. I',m 5'7" and 170lbs for reference.
Power: eh, yeah, it goes.
wheelies: yes. More than it should.
stroker crank, stock bore.
ss valves/springs/stage II hotcams
FCR39 carb, E airbox/intakes.
full FMF exhaust
drz 1-3 gears, act wide ratio 4-5.
14/44 gearing SM
14/47 gearing dirt
Edited by albani
Stroker alone? Not sure. With everything else it makes for decent power over stock.
 if you aren't splitting cases for a full go through, just put a big bore on it.
