Time for top end work (Valves, Rings, ...) - Need some advises
Hello guys,
I have a 2008 DRZ400S for little more than 2 years now. I now have 25000km. I have been noticing a considerable amount of oil consumption (>200ml every 1000km). I reshimmed the exhaust valves a few times (current shim: 298 and a 305). The current clearance for exhaust is .18 and .17mm so again out of spec (.20-.30). As for Intakes I am using 282 and 285 with clearance at .14 and .13.
Current mods: JD Jet kits + 3x3 airbox
My current plan is to replace/do:
-Exhaust Valves
-Intake Valves
-Valves Seals
-Head Gasket
-Piston Rings
-Adjust Carburator
-Clean the shit off the head and piston
Should I buy OEM or ?
Any other advise?
Here is a few pictures:
https://flic.kr/s/aHsks9pXqR
Thanks,
Franck
I would look into fastheads.com for the head work . I had them do work on my 450r a few years ago . They have been involved in moto for quite a while .
i sent my head over to them for a complete revalve, they did an awesome job.
I personally would use all OEM components. Not sure about a service provider, did mine myself.
Oem would be best for sure.
Soda blast the head. Hot tank it. Relapping the valves can be somewhat time consuming, but its easy to do. See if you can borrow a valve spring compressor; I had to buy one for $60. I use the wooden sticks and the paste to lap them.
