2003 XR80 HELP
I recently picked up a 2003 xr80 for a good price from a friend. His dad was hassling him about the bike taking up room in the garage and since he didn't ride it any more I thought it would be a good bike to get. When I got the bike there was no gas in it. It sat for close to two years, I got the bike Cleaned the entire carb jet pilot and all, changed oil, put new plug in it, new air filter, put a spark arrestor on,p. When I start the bike it idles but will cut off. Even if your riding it will cut off, but you won't get far if you try riding. I'm kind of stuck with wha to do, can't think of what it could be. New lines?ImageUploadedByThumper Talk1453339676.066931.jpg
Yeah but if he rigged it somehow, it could be fault, either that or check your ignition coil, it could not be giving enough of a spark
Clean grounds and connectors for sure. The spark plug cap winds onto the wire. you can remove the cap from the wire and trip just a 1/4" of and then reinstall. They can get a bit of corrosion in there.
