98 YZ 125 Frame Compatibility
I have a 98 YZ 125 with a huge dent in the frame.  I found a cheap 02 YZ 125 frame on Ebay.  I'm wondering if anybody is aware of any modifications I'm going to need to do to the frame before I swap everything over.  Thanks!
Where the subframe mounts is not the same. It can be done but is a lot of work.
It would be easier to find the correct year chassis.
For one: gas tank needs to have tabs for the bolts
The connections for the subframe would need to be cut and welded lower for your subframe. If you got the 02+ subframe than your silencer probably wouldn't fit, possibly rear fender/ side panels/ air box as well.
If I was you I would ether replace it with the same generation frame and modify nothing OR get the '02+ plastic, tank, air box, frame, subframe, silencer? and basically convert it to 02-04.
