DR650 All-Balls wheel bearings seals ?
kind of an odd question..
I'm replacing my rear wheel bearing with NEW All-Ball Racing bearing and seals.
My question is, after I press in the bearing on the non-drive (brake side) there is NO room for the dust seal.. as if the bearing is too thick, however, I check my old bearing and they are the same size. YES, I have the new bearing pressed ALL the way to the bottom.
more information.. I removed the new bearing and measured the bore with calipers and then measured the bearing and seal together.. once again, the seal will NOT nit after I press in the new bearing.
any advice?
thanks in advanced.
