Valve check at 30 degree temp
.is it too cold to do this check now or would it be the same????
..Did lower end rebuild.. Just completed top end. One intake valve is tight...
it to cold to check this...
Clearance will be larger if colder than room temp, or your the normal temp you set them at. That means a cold motor, too, that's at that temp, not a warmed-up motor checked outside in the cold.
Thanks.... I was thinking the same.... Appreciate the replys... So my friend brought his shim kits over.. There huge compared to the crf250.., guess off to honda dealer.
Never did the formula yet. New to it.... Any helpful sites or tools..
