2009 450 water pump help.
Hey guys,
Having a very tough time figuring out how the water pump seal, shaft and bearing come out of the side case. I've looked and looked on web but no luck. Can anyone help? Thanks. ImageUploadedByThumper Talk1453438615.847863.jpg
I had a look in my manual and it said you press the shaft out and used a bearing puller to get the shaft bearing out
Edited by Aus450
Here's a few more pics that might help
Between the service manual and these pic you should be good.
Edited by UHF2
It is pressed in....best bet is take it to a shop and let them do it.  It should only cost you like $20 tops to take it out and press the new one in.
