JD jet kit for slant FCR carb, few questions, 2001 Drz e
Hi, I have a 2001 Drz E
I can get a JD jet kit with the Scott fuel screw (longer) for 75 pound,
I've used the JD jet kit on a Drz S and results was great;)
Since I've got the Drz E in parts so why not do it when the carb is out of the bike, why not?
Would the kit come with everything I need for the Drz E slant fcr carb? Also I've removed the CE,
Got a after market exhaust
Snorkel removed same as 3x3 mod
Location is South Wales ( cf45 4pg )
I'm not clued up, on jetting to be honest but with help of this forum and JD instructions I done the Drz S with ease
Yes the JD kit comes with everything you need and the instructions are easy so follow the jetting recommendations just like you did with the other bike/kit.   If you removed the coast enricher and just connected the two ports with a piece of hose you will be fine.   If you plugged the ports then you will need to bump up the slow air jet to a 100 from the standard 60.
Thanks,,, roll_it_on, that's great, yes I've connected the 2 ports together so I don't have to change that jet,
I'm going to order the kit now then,
Many thanks,
