Kawisaki KIPS
So i recently blew up my bike and had to have it rebuilt and everything so i started rebuilding it, got everything done except the KIPS. I CANNOT figure out how to put it back together. Its just the part that goes from the bottom end to the top end that i cannot figure out. I heard that it has to be timed correctly. The rod goes up from the bottom end and from there i dont know how to put it back. I dont know where to put that spring thing. Can any one help PLEASE. Thanks.
Breathe. It will be ok.
What year/make/model?
Here's what I have on me right meow.
I bet you'll find more with a search of thumpertalk.
Edited by SellYour4Stroke
Is this what yours looks like? (If it is) Make sure the retaining bolt (below shaft) is out. In the picture I have the top part loose. It slides over the black shaft that actuates the valve, held in place with a C-clip. It's a little tricky sliding it in. You have to turn it as the shaft is dropping, and it just barely clears the cylinder housing. I turn the loose piece on top clockwise until it stops. Then as I'm lowering it the shaft, gently turn it counterclockwise just as it clears the housing. Hope that helps.
