2002 rear master cylinder.. anbody upgrade to newer style?
Has anyone put a newer rear master on their steel frame bike to omit the remote reservoir?
wh
It's easy. I mounted a system from an 03 on mine
what do i need besides the M/C?.. Will my old hose work? Also what years will work?
Edited by Snider
I'm not sure about years or if you can just replace the master cylinder. I put the whole system off an 03 and it worked. Hopefully someone else knows or maybe just buy a master cylinder off eBay and see. Theoretically it should work
If you are just doing the master swap then I believe they stay the same on up to 04 (could be even newer). I know the whole system from 04 down is the same. 5NY, then changes to IC3. I just swaped to a complete 04, since I don't have to worry about the green/red crap of Cal-Hell-ifornia!  👍
Yep. We swapped a master cylinder off a 2004 onto our 2001 YZ125. All you need is the master cylinder, nothing else.
Fall-off-a-log simple upgrade.
I think ALL years will work. The components are pretty basic and are not constantly revised.
Check parts lists if you are unsure.
Edited by CaptDan
Yep, 125 to 250 is the same for 03-04 also. Even complete system if you find one on fleabay.
