Stripping....... JIS screws kick start
Had a bit that fit, gave it a twist and snapped the bit in the screw head. Okay got an impact driver that only has a P2 and P3 bits. Tried but failed with the P3. Started to strip. I know they're jis screws. Someone on advrider mentioned some screw heads from ace hardware would work that were used for dry wall. No bueno
Any advice. I do have an extractor set but I cringe thinking of all the metal shavings going everywhere in the case.
Should I wait for some.JIS screwdrivers or just try hammering the he'll out of the driver some more.?
# 1 Phillips works for me.
Do you use an impact driver and if sohow many times do you hammer and twist
I think i figured out my problem. Seems I may have bought a defective inpact driver. It will only tighten. Tried to push.and twist it left in a vice. No motion only tightening. Either way can't to replace these with Allen head style. First time harbor freight tools has let me down
Thanks fellow tt's!
When I need to.  Usually one good whack.
Afraid to put heat to the screws since the screws are inside the case
Use a soldering iron, pressed against the screw head...not a torch.
As a last resort use centre punch to make a nice indent in the screw head then hit it again in the direction you want to turn
  • Like 2
A good heat gun WILL help. I've actually used it to remove float bowl screws. Didn't damage any rubber components...Also, good idea above, use a blunt punch to flatten out the burrs.
#3 bit not 1 or 2.  Drive the bit in first without the impact to assure a good fit.  Then put the bit in a working impact driver. Set the driver to loosen. Set the driver with bit on the screw with no pretorque. Just hold it straight on.  Whack the driver with a hammer.  Has never failed for me.  It is not frozen in place or Loctited, it is just tight due to the conical shape of the head.
I had the same problem with a Harbor Freight impact driver, but if you play with it some it will change to loosen.
  • Like 2
Well I tried using a real impact battery,powered driver and shredded the screws so I used my speed out screw extractor Worked like a charm.
Now the question is, I tried my best to cover the case with plastic but Im sure some metal shavings fell in. My best bet.just to change the oil once with Dino oil and then fill it with the good stuff?
Also anyone know what size Allen bolts I can use to replace the stripped ones? Going to aces hardware tomorrow but would be great if someone knew right off the bat
6mm flat head. I don't know the length but you have a sample.  Probably 10mm or 12mm.  (length of a flat head screw includes the head)
Those screws are countersunk for alignment reasons, only replace them with like in kind.
