Blown top end, why?
Hey guys so I did my top end on my kx250 and I did the first heat cycle then realized that that my crank seal was blown so I took apart the bike and took the new piston out. Then I got new cranks seals bearing ect put the slightly use piston back in and then I started up the bike on the stand, it ran for a 5min and then it died I tried to kick it on but nothing, then I checked the compression it was at 90 and ya just never turned on. Btw I got the cylinder honed too. HELP ME!!
Crank seals normally don't require crank removal .
Take the thing apart and the answer is there . All I can thing of that would kill it that fast is
Piston wrong size
Didn't hone properly
Or honed a nikasil
Didn't oil when putting together
Dirt!!
Piston in wrong
Really lean and burned out
Most likely it's a combo of these
TBH most of the time something that fast is normally either user error or something was worn out and didn't get replaced with the rest of the stuff
I'd just take it apart and see what sort of damage you got and be more careful rebuilding .
Who honed it ? How ? Did you measure everything ?
Btw if you honed a nikasil jug that would do it
Piston wrong size
Or honed a nikasil
Dirt!!
Piston in wrong
I dont know how but I got it running I just kick it about 100 times lol and it started right up and idle
shut your face if you dont like it dont look at it
With all due respect there's a good reason for this rule and being hostile about it is a good way to get banned or have your posting abilities taken away
You won't be posting much longer with this attitude.
Read and follow or you're out of here.
What are the rules concerning the use of this site?
No personal attacks. If you debate, attack the topic, not the person.
No unauthorized commercial/promotional use of ThumperTalk. Members must not use the discussion forums and/or private messaging as a vehicle to promote or advertise the products, services or events of any business that they are directly or indirectly associated with. If you'd like to reach our members with your message, contact us.
No trolling. Trolling is starting threads or replying to posts with the purpose of getting a rise out people. For example, starting a thread titled "Yamaha Riders Suck" in the Yamaha bike forums.
No non-sense posting. If you don't have anything of value to add to a thread, don't reply just for the sake of posting. It's just more fluff readers have to weed through to find the information they are looking for.
No posting for sale, free, wanted or trade ads in the forums. Ads are only permitted in the classified section or your profile signature.
ThumperTalk is a PG13 community. This means no excessive profanity, vulgarity, graphic or sexually explicit content.
No cross-forum posting (creating the same thread across multiple discussion forums).
Moderator conflicts. Should you have a conflict with a moderator, work it out with that moderator. If that fails, contact the site administrator.
No unauthorized group buys.
We reserve the right to monitor, delete, edit, move or close any post, thread or private message for any reason. In addition, we reserve the right to block or restrict any user from access to ThumperTalk for any reason.
If you post something that ThumperTalk deems unacceptable, that post/thread will be deleted and you will be told why via private message. While we don't expect you to agree with any particular action we take, we do expect your cooperation and acceptence. Any bitching, whining or pissing & moaning about it will result in your immediate removal from ThumperTalk. This includes taking your case to the streets (public) in an effort stir the pot and disrupt the community.
ThumperTalk is a private club and we reserve the right to determine what is and is not appropriate for our discussion forums. If you don't like what we do or how we do it, please exercise your freedom of choice and find something that better suits your personal tastes. If you have a suggestion as to how to improve ThumperTalk, post it to our suggestions box.
Bottom-line, treat others as you'd like to be treated yourself, use common sense when posting/replying and have fun!
Cylinder honed or plated?
Piston in backwards...
it turned on I dont know how but it turned on and and idle shortly after that I had to shut it of because one of my lines poped off didn't fully tighten the hose clamp antifreeze got everywhere lol
Backwards piston is possible.  If you put it in like that it might start and run just long enough for a ring to snag on a port since the alignment dowels would be in the wrong place.
Take it apart again.
its not backwards I put the arrow facing the exhaust
Did you take it apart yet?  90 psi compression means you have a serious problem.  Either the rings are stuck or the cylinder wall is damaged.  Rings can get stuck if you have a foreign object in the cylinder that gets mashed against the cylinder head.  This can collapse the rings lands and stick the rings.  If something got into the motor while you had it apart that would do it.
This was 130 psi. Something is seriously messed up to have 90
Edited by Yamahace
