Brake levers design for kids hand size?
My sons hands are not big enough to keep on the throttle and pull the front brake lever on his kdx50.
Are there aftermarket levers that have a design that places the lever closer to the grip?
Has anyone have a good tips on modifying the existing levers?
My daughter had the same issue. All I did was lube up the cables really well so the pull wasn't as heavy and told her to figure it out, which she managed in no time. You can also leave some play in the levers. They will rattle around if you do, but even the levers for the pw50 are kinda big for a kids hands. I would assume there about the same size as the kdx levers, but they might be worth checking out.
I came acrossed a used lever on CL I'm going to try to heat it up and bend it to get it closer to the throttle.
I will post if I'm successful.
