Grease on the fork leg?
SO, how many guys really pack grease betwen the oil seal and the dust wiper on a YZ, like the manual says?  I've never done that step but I was wondering if I'm alone in skipping it.
Used to years ago used to use some vaseline or grease to keep from drying out... but any more I am pretty sure seals are good and it would make dirt actually stick in there.
"Apply the lithium soap base grease on the inner
tube."
Taken directly out of the YZ 125 manual. As I understand it, it says to only apply a thin layer of grease on the inner tube.
As from personal experience.. don't "pack" it. I did a thin layer once and it was ok, then next time packed it quite properly and had oil dripping down both forks in a matter of minutes of riding.
Don't know how long the seals would hold a thin layer, but I'm definitely doing some research before trying it again.
I do it when installing as well as periodically. I believe the purpose is to keep them from drying out. Just a thin layer, never packed.
Edited by YZJ
After a bike wash, I like to finish up by rubbing suspension fluid or even ATF on the legs to clean them up a bit. Removes the water spots and help keep the seals from drying out.
  • Like 2
I don't have time right now to confirm this but I think the Yamaha manual suggests "packing" or liberally filling that gap between the seals.  Not exactly the same as just putting on a coating.
I bet you have smooth silky legs also.
Thin layer is all I have ever done.
I've read some posts of mx guys doing it . I have but don't most of the time. It wipes out fairly quickly.
I remmber a guy keeping a felt pad inside with uber lube on it.
couple times a year I would drop the dust wipers,apply thin layer of grease around tube and compress forks several times! Wipe off excess.
  • Like 2
