2015 Suzuki rmz450 TPS value
Hi.
Dose anyone know whats the 2015 Suzuki rmz450 TPS (throttle position sensor) value from the factory - 0.something?!
Tnx
.5 TO .7
You pick the value based on the map changes you want to make.
The higher the resistance the more you are in the 'partial throttle' map and out of the 'idle' map.
Thanks.
I asked because I swapped original exhaust against Pro ciruit Ti-6 and in the lower rpm-s there is something wrong - it pops I think (if the word is right). And in the tight corners it wants to stall and sometimes do. I checked TPS and it was 0.58. I have to try then higher numbers? 0.58 - 0.70? The problem came right after exhaust Change.
More likely an increase in flow is creating a lean condtion, not a tps issue.
Should re map
Check you header crush washer and make sure all pipe junctions are air tight using high temp silicone
  • Like 2
Should re map
All checked and ok. If i accelerate or just going on full gas theres no problems. When I drop the gas or keep it constant in lower rpms then the problem appears.
That certainly sounds like a lean map to me, assuming there are no mechanical connection issues with the electrical or plug components.
Yes, lean map is on the bike now. I put it because I race winter on ice. Autumn I had rich map on bike when I ride in sand. I dont remember was same problem then or not. Thanks anyway. I change the map again and then it will be clear is that lean/rich issue. THANKS.
