Shim restacker gurus here is question
Hi Guys
I have Fox snowmobile center shock
The shock has 37 mm diameter piston with 3 x 15,25*6,5 ports for damping and 3 x 6,25 diameter ports for rebound
Shim stack is following
Comp
Base plate 28 x 2,3 mm
33 x 0,25
20 x 0,25
23 x 0,25
25 x 0,25
28 x 0,25
32 x 0,35
3 * 33 x 0,30
28 x 0,15
4* 33 x 0,20
Piston
30 x 0,20
22 x 0,20
18 x 0,15
28 x 2,10
nut
piston rod is 1/2"
Question goes how this package looks in restackor?
What if i change the piston rod from 1,2" to 5/8" piston rod?
Regards,
Skoo
Restackor creates damping profiles ,without having a good baseline to work against you will know nothing , and you need way more port geometry than you gave given ,have a look on the website
Port geometry
Drod = 12,70mm
Dvalve = 36,83 mm
w.seat = 0,45 mm
Vspec = MVC
r.port = 9,00 mm
d.port = 6,50mm
w.port = 15,00mm
n.port = 3
h.deck = 2,50 mm
dleak = 0
dhrt = 10,99
N.thrt = 3
N.click = 10
Those F.stack and u.wheel values is not so easy to figure out.
Let say that there is 350 mm suspension travel and shock linkage is 1/3 and average speed like 60 kmh. Bump heights 200 mm and more
I'm sorry but I don't have the time to run it for you ,maybe someone else will
