Over filling transmission side?
I over filled it just a little bit shouldn't hurt it right heard it keeps the whining down but of course the other side gotta be almost spot on but I did put a little extra in there !
You're fine. An ounce or two won't hurt anything.
its good insurance for the kit starter bearing.
I put an extra 50-100 ml in the engine side all the time.
also have an over sized clutch cover which holds an extra 200ml of oil, I also add an extra 100ml on top of that.  I think I end up putting 1L into my clutch side whereas the stock is around 650ml I think.
I put 650ml into my clutch side with a stock clutch assy.
There is no kick start bearing. But yes alittle extra is fine.
