XR250R Suspension Settings- Trail vs Desert
I am entering my 2nd season of off road riding (long time street rider) and trying to learn the desired suspension settings on a stock 2003 XR250R.  I have decided to leave the bikes suspension stock for financial reasons and realize it is undersprung for my size.  I walk around at 180 pounds and am 5'10.
I rode in my first poker run yesterday which was a desert setting (Dirty Poker Run, Vantage Wa.) with various types of sand and lots (I mean lots) of whoops.  My previous year was primarily trail riding in the PNW which has alot of rocks of roots.  I had my compression and dampening set to their softest settings and had some real issues yesterday in the sand and the whoops.  I found my back wheel sliding alot (like I was on ice) and my front plowing frequently. I think the plowing was coming from my front compression being too soft and know that my struggles in the whoops was alot of technique issues and most likely dampening too soft as well.  Watching the other riders fly by me only confirmed this.
Am I correct that my suspension should have been firmer for the sand and whoops?  Would I be better served just to leave the suspension in their factory settings (manual calls for 8 out I believe).  I realize riding an older, stock trail bike can't compare to the KTM's and Husky's that flew by me all day but I am hoping to at least maximize what I am working with.
Thanks for your help and advice.
At minimum , install stiffer front springs . I think the rear is fine for your weight.
If you are broke, try to turn compression 1 click from full compression dampening (Hard = slow)
On the rear, if it is pitching you up and sideways put in more rebound control. If you are not getting good traction take out some rebound.
The stock suspension was terrible for me. I bought heavier springs, and took the shock and had it revalved by Cannon Racecraft and the forks and had Bruce Triplett do the Terrain Tamers mods and now the forks are "Excellent" and shock "Very Good". Spent about $900 on suspension now I am racing those KTM's and Husky's. I have along way to go with lots to learn but out of 97 riders who finished the B race Sunday I beat 92 of them. All name tags. Stock motor on my 250.
I should add that it was a woods race.. rocky and technical with some fast creek sections. Next race will be sandy and desert like I don't know if I will fair as well there with limited horsepower.
Edited by Firestone
Your back wheel sliding sounds like a tire issue, if in fact it was sliding and not hopping.  Your tire probably wasn't suited for the terrain you were riding.  As for your suspension, that is a very personal issue.  Guys have spent tons of money on XR suspensions and love it.  I haven't had to , I can keep up with guys on CRF450Rs with very little problem just as long as it isn't a horsepower race.  And that's with stock suspension.  I'm 205 lbs., have stock springs and have never bottomed the front end.  Yes, there is deflection due to lack of rebound, but after 13 years on my 03 I guess I've learned to adjust for it.
As for the lack of hp, that has been discussed here numerous times.  The best bang for your buck is a big bore kit.  I'm very satisfied with the power of my ~280 kit, but there are some that say don't bother and go 300, but its more expensive.  Exhaust is a total waste of money (other than a bit of weight savings).
Disclaimer:  I don't race, just ride fast and have for a lot of years, so if you are racing, guys like Firestone can give you a better point of view. ;)
Thank you all for the advice. When it is recommended to "add" some damping, that means turning clicker towards "soft" correct?
Adding damping would be increasing compression resistance, so clicking towards hard
If you're riding sand. Slide the fork tubes down in the triples.  Till they're flush with the top.  Being since you're bad undersprung for the stock stuff you're going to want to go in on the compression on both the front and rear from the stock settings.  Turn the compression in on the front to keep it higher in the stroke and keep the front end from diving and transferring weight to the front wheel.   Rebound in the front is non existent unless you want to do a shim swap.  But that is very time consuming to change and even harder to dial in.    Compression on the back you may want to leave close to stock, or maybe go 3-6 clicks harder from stock.  This should keep more weight transferred to the rear and keep the front end lighter.  For the rebound on the back, you'll want to also turn that in for sand to deaden the rear end.  Don't want to go too much otherwise you'll start to pack the rear shock down in the stroke and it will become harsh and kick side to side.
You'll have to see what works for you, but this will give you a direction to head.   Overall you want to keep the balance of the bike so that you don't dive in the corner, but also keep it from pushing in the corner.  Think more chopper ish than up on the bars ish.  (if that makes any sense)  lol
But in reality, the XR250R suspension is going to be leaps and bounds away from a modern suspension, so if you've rode a modern bike and have now switched to the XR don't be looking for some magic pill to help solve the issues.
Thanks all....good stuff.
I've had and raced several XR 250s, last one I had was a 2003 I bought new. It was 100% stock except heavier Fork Springs. I did really well on that bike always a top 20. XR 250 is a great bike. I'm an a-level Enduro expert level desert racer. I had a KTM 450 before the XR, KTM wonderful bike but the XR gave the guys fits.
  • Similar Content
    • By Kev_XR
      If you own an XR250, many of these tips will apply, however, the carburator jet sizes will be different.
      It really helps others answer your questions.
      I will fix them as time allows.
      Until then the Search Feature and enter "kevin's xr400 mods".
      The results will bring up most of the links.
      Here are some frequently asked questions I have answered before.
      Which XR should I buy?
      The longer the straights, the taller the hills, the deeper the sand; the bigger XR you want. The tighter the trail, the smaller hills, firmer terrain; the smaller XR you want.
      The XR400 has a great motor that will pull you almost anywhere. You can be sloppy on a hill climb on an XR400, where you have to keep the 250 singing. The XR400 weight is most noticable when you drop it or try to stop it going down a long downhill. (Moooomentum!)
      The XR250 feels like a mtn bike compared to the XR400. My friend rode his XR250 for years before decided he needed more power. Even then you can add a 300 kit and get good power.
      If you were heading to ride fireroads in Baja, I'd tell you to get the 600/650.
      To the tight woods, get the 250.
      A lot of both, the 400.
      Dual-sporting? Go bigger for more freeway, but don't show up at the trailhead with too big of a bike.
      All of the XR's are great. Pick the one that fits your needs.
      Gordon's Mods for XR400 (Uncorking the bottle up performance)
      XR400 History
      The changes to the XR400 have been listed here several times. This list appears to be complete.
      In addition, HairyScary discusses how to tell if a part has been updated by the part number. Good tip!
      XR400 history
      Getting the Spark plug out
      It seems the MotionPro spark plug socket does not work on the XR400R, but works on the XR250R.
      There is an OEM tool kit being sold on eBay that seems to work.
      717448 XR400 oil change
      Here is a way to make changing the oil much cleaner.
      This tips is really handy if you have a skid plate.
      XR400 oil change
      XR400 FAQ by Paul Gortmaker
      Paul usually has very good info.
      Small bolts
      BE CAREFULL with the bolts on the oil filter cover!
      An oil covered bolt will not torque at the same rate as a dry bolt.
      The friction doesn't build up, the force simply builds until the threads strip.
      This is the reason many people strip out these bolts.
      Here is an execllent website on bolts, oil, and misc values.
      Did you ever wonder why a 8mm box wrench is half as long as a 18mm box wrench?
      It is shorter as most 8mm bolts cannot take very much torque.
      I highly recommend getting getting an 1/4" socket set.
      I bought the Craftsman set at Orchard (owned by Sears), which tends to sell them for less.
      What is the Snorkle?
      This place has a description and pic, it's easy after you pull the seat. I siliconed a piece of coarse screen (fiberglass) over mine to keep bugs and stuff out. - NORTEXT
      717439 XR400/250 Pre-Filter
      After pulling the snorkle, there is a big hole on the top of your XR400. My friend showed me this prefilter trick.
      767409 XR400 Engine Bog, Pilot jet, and the Fuel Screw
      On XR400's twisting the throttle from fully closed to wide open will cause the engine to "bog" or in some cases die.
      831305 Valve adjustment (Am I retarded...)
      Inspect and adjust valve clearance while the engine is cold (35C, 95F).
      Valve adjustment
      389095 bigger jets (Lists stock jet sizes.)
      96-97 XR400's were jetted assuming you would remove the intake and exhaust snorkel.
      98 and later XR's were jetted assuming you would leave them in.
      bigger jets
      739907 Cheap Tool for Setting the Fork Oil Height
      There are some really nice tools out there for doing this job.
      This tool costs $4.49 at Kragen.
      Cheap Tool
      392932 high altitude jetting
      There are two big factors for jetting, elevation and temperature.
      Allen screws for the XR400 carb
      This lists the screws you need to convert the XR400 carb to use allen screws.
      Allen screws
      Screws for the brake and clutch after removing the stock handguards
      TBD - There is a post with the shorter screw part numbers for after the stock handguards are removed. Use search.
      Very quick engine hop up
      This is a very minimal change that should take less than an hour.
      Most of that time is removing the float bowl (3 screws).
      If you decide to do the full "Gordon's Mods" later, you will need to replace the jets again.
      o Pull the intake snorkle.
      o Add a UniFilter.
      o Pilot jet to 55, main jet to 155. (Assuming sea level and moderate air temps.)
      Source: Motocross Action magazine.
      Quick engine hop up
      Gordon's mods
      Baja Designs Baja Baffle with 96' spark arrestor.
      Pull the intake snorkle, UniFilter, 60 pilot jet, 162 main jet.
      (Depending on altitude and temp.)
      What to add to a new XR400 or XR250?
      Acerbis wrap around style handguards (saves levers and bars as they don't dig in)
      Baja Designs skid plate (Made by Utah Sports Cycle)
      Acerbis fork/disc protector
      Grease headset and rear linkage
      Spend you money on the suspension, not a pipe!
      First get some stiffer fork springs (96-97, 98-99 years)
      Fork revalve (cost: 2 qts of oil & time)
      Shock revalve (cost: oil, nitrogen, shim stack, friend who knows shocks)
      Jetting for Altitude (XR400)
      Assuming at sea level and 68 degrees, you would use a 60 pilot and 162 main.
      At 5000 feet and 68 degrees.
      Jettting correction:
      Main 0.96 * 162 = 155 -> 155 main
      Pilot 0.92 * 60 = 50.6 -> 55 pilot
      Due to your elevation, you have less air and less fuel.
      Your bike will not behave the same as a bike at sealevel.
      First, check the fuel screw. If it does not affect the idle speed, you have the wrong one.
      kevin's xr400 mods
    • By Child
      Can we make a sticky thread of pictures? I've done search for pics but I want to see all sorts of bikes just for ideas on stuff without having to go through tons of threads. Not trying to sound whiny or anything, but I think it would be nice to do what they do in the CRF250X forums with a sticky thread of just pics, no comments or anything. Think we can get one of those rolling here?
    • By kawamatt2
      Ok guys, add one more to the list of riders attempting the USD fork swap to an XR frame. Quite a bit of research here on TT and ebay hunting brought me a pretty good deal on a set of forks, triples, and stem from a 00' CR 250.
      There are a few different options for adapting CR style forks to an XR. Bushings for upper and lower CR triples can be made to allow use of the stock XR stem. Specialty bearings can also be purchased to allow use of the stock CR stem in the XR neck. And finally what seems to be the most common; modification of the stock CR stem to allow use of XR sized bearings.
      I obviously chose to pursue the third option for a few reasons, the most prominent of which is serviceability. I wanted to keep as many wear items at possible as stock parts. This has two advantages; availability and price of replacement parts. $45 dollar a pop "specialty" thin section tapered bearings don't sound too appealing especially when being used on a 12 year old dirtbike.
      So now we can get to the meat of the issue; modification of the CR stem. I should begin by saying that i am NOT a draftsman. I've taken a few classes on engineering measurements but am far from an expert and probably only mildly proficient reverse modeling components. With that said, the first order of business was comparing an XR stem and bearings to a CR stem and bearings. Shown below.
      A little closer look at the XR setup.
      And the CR setup.
      Now to get out the calipers and model up the stock CR piece. I used a cheaper set of calipers and suspect their tolerance is +/- .01mm. Good enough for gov'ment work though! All dimensions in millimeters.
      Now to modify the CR stem to work with the XR bearings while remaining compatible with CR triple trees. There are a few things to say about why i did some things the way i did but most of the thoughts are included in the notes section of the drawing.
      With a resized stem we run into the problem of mounting the top triple clamp. The hole is too large for the stem. An insert bushing must be made to resize the hole in the clamp.
      Finally what the stem and bushing look like together.
      Last one. The difference in how the top triple clamp is located on the stem. The CR is equipped with a chamfer that provides a stop for the tree while the XR's triple appears to be limited only by the threads for the castle nut.
      So... would like to hear your opinions on the execution of the stem modification and bushing. I think having these drawings will make it simpler to have the modifications performed as opposed to asking the machinist to completely reverse engineer the part him/herself.
      And a final query: Anyone know the thread callout for the two threaded portion of a stock XR steering stem? My drawings show the outside diameter of the threaded portions and i have a cheap plastic pitch gauge that tells me a pitch of 1.0 but i am looking for something more concrete than what i have.
      Thanks for your thoughts and opinions.
    • By ATJ_Number_1
      I'm on strike 2 here but thankfully this isn't baseball.
      The reasoning and my history. If you haven't figured it out yet I've done a crap load of work on these motors over the last 7 years but they have had 4 wheels around them. In the EX world there are a lot of carburetor options and although many are great there's a cheap alternative that runs 95% as hard as the high dollar options, some even liking it better then aftermarket. When I joined up here in the 2 wheel club I was shocked that the only accepted option was $400 for a 36mm Mikuni Pumper that isn't any bigger then stock! That cheap alternative for the EX is an 04-05 trx450r carb. It's 42mm round slide Kiehin piston-valve with accelerator pump and a mildly modded 400 loves it with a surprisingly strong bottom end yet. Yes I said 42mm!
      So as I build my XR4 I already know that I'd be shooting myself in the foot if I settled on a 36mm carb because I like bigger bores and cams and this motor likes bigger carbs. Makes sense, it is 400cc. Don't get me wrong though, the Mikuni is a real nice pumper for a stock bike and would seem fine on a well modded machine too but this 4 stroke is like every other one in the world in regards to when you go big inside, you want to go bigger outside or you're missing out.
      Whether the info is appreciated or scoffed at I'll post up my findings one by one as I try to find viable alternatives. When I say viable I mean still being able to use the stock environment and not needing a ton of work. I'm sure collectively this is not a new idea to search for such a beast but I enjoy a good project and I like cheap alternatives when they produce results.
      Currently the "test bike" is a 2000 Xr400r, snorkel removed, Uni filter, stock engine, stock headpipe and a 4" supertrapp slip-on with 11 discs.
    • By XL100allnightlong
      Just wondering if there is any tricks to polishing the stock headers on an 02 xr 400 to bring back the original copper color? If not ceramic coating them sounds like an option?
