Mounting a Damper with Roxx Offset Risers on an S?
I'd like to mount a damper with minimal alteration to my current riser and bar setup. I know I'll need to use some kind of upper bar clamp, I'm just wondering if there are any that will work with what I have.
I could always ditch them and go with a different bend if it's easier. As always pics are welcome. Thanks in advance!!
Ram mounts will have to go but that's ok
Edited by DRJH1999
Rox risers and Scott's don't work.....been there, dunn that.
 I had 2" Rox risers and I had to rotate them forward to make it work. You could get taller Rox risers (3 1/2") but then you risk not having long enough cables. My solution was just to bite the bullet and get a BRP triple made expressly for this situation.....
Nice, how much did that run you? Doesn't look cheap
The triple is actually not that expensive. Checks Scotts Web page but I think it only adds about $150 to the price of the stabilizer setup.
Like PTGarcia says......check their website for current prices. I got mine a couple of years ago.......
