DRZE Nomadic rack fitment.
I have a DRZE and I purchased a Nomadic rack. Because of my FMF exhaust I had to modify the rack to fit. The clamp style mount for the FMF has a spacer that pusheds the clamp outboard to keep the muffler away from the tire. The 3rd support leg of the rack needed to be trimmed to allow for the spacer being there.
I also had to trim the plastic ever so slightly. as the leg just touched the bottom of the fender and the back of the side number plate. I have after market plastics so that might be my issue.
Overall it isnt bad for $90 BUT it has some design changes that SHOULD be made to make it a better product for the E model.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
