I am attempting to put a little project I picked up together  XR600r Frame and engine are 93, but the forks, swingarm, and wheels appear to be 87 or so, as it has the gold rims.
I wondered if anyone could help with what I needed to do to get the drum brake operational.   This is a budget bike and I would like to try to use the components that I have.   I pIcked up a 87 pedal and rod, but it will not work as is.   also, if anyone has close up pics of the brake pedal area, that would be helpful.
I know I could get to 93 brake components and swimgarm, but would prefer to just use what I have already.
The problem I imagine is the drum brake.
The pedal is different on a hydraulic rear. This is all I think...the bikes arent in front of me...
Id think you can weld whatevers needed to mount it.
But you have to make the pedal activate the drums lever. Which the hydro lever wont do. It can probably be made to somehow. But it sounds like a project.
Look up drum to disk conversions and do it backwards.
The pedal will be your issue.
  • Similar Content
    • By Charles Mrizek
      This replaces part 9 in the exploded parts diagram for the 85 86 87 xr600r.
    • By XR-CJ
      I have this issue several times and cannot seem to figure it out. The four clutch spring bolts are the weakest bolts I have ever come across. I am not sure what the torque specs are, have the shop manual, have searched online and I can only guess it's around 4 ft/lbs. I have been told 8 and they seem to break every time around 7.
      What is the proper torque for these bolts?
      Should I find stronger bolts? I would still stick to the proper torque, but feel as if these things are butter.
    • By XR-CJ
      Prior to reassembling the case, I tested the shifting and it seems the center fork attached to the shaft seems to stick at the steepest section of the drum. I have cleaned and tested all forks and surfaces for smooth movement, tried it with silicone and oil. With very little help, it seems to shift ok, but without the help, it binds.
      Can I assume that once it is together the oil lines are attached and oil is added to the case, the binding will stop? I have tested every scenario short of assembling the entire motor.
      Should I be able to successfully test the shifting with the case apart?
    • By Charles Mrizek
      contact me if you're interested.
