Stripped yz125 plastic bolt and missing radiator bolts.
[ImageUploadedByThumper Talk1458530028.861374.jpgattachment=311359:ImageUploadedByThumper Talk1458530000.593197.jpg]
What shall I do? How do I get it out no damage to tank. Tried everything but drilling.
Even Vise-Grips (locking pliers) don't grab on to it?
How about using a Dremel to grind a slot to fit a flat blade screwdriver.
Negative mlatour
Have you tried an EZ OUT?
Problem solved. Drilled till it came off used needle nose to unscrew the threads. Replaced with this till I order oem bolts.
