1998 WR 250 K - Oil leak on power valve cover
I just had my entire engine overhauled! Bike still on first tank of fuel after rebuild, and then I noticed oil seeping out of plastic part of pv cover.
I am 8 hours away from the nearest mechanic, so taking it back is not an option right now.
Is it safe to ride like this or am I compromising the new rebuild?
Thanks in advance.
That "L" shaped seal is kind of a pain in the rear, I'd pull that cover off and make sure that it's installed correctly.
Thanks cowboyona426, I also think it might be the gasket or something there.
However, I read somewhere that if the bike is not jetted properly, the excess 2-stroke commonly leak from there.  Any thoughts? This would make sense as I feel the bike is not jetted right at all.  Even after I let it warm up for a good while it seems to bog down in 1-3 gears when I open the throttle.
I suspect is is because the bike was tuned at sea level and we are about 5000 feet in elevation.
That I can't comment much on but it does make sense.  My 98 WR has had very little run time since I acquired it because it needs some work to be rideable.  If you are riding at 5k elevation then I'm sure the sea level jetting is rich for you.
