Cr250 front sprocket loose
The front sprocket on my cr250 has play in it even with the bolt torqued down, maybe im missing a spacer or washer?
Is it a stock sprocket? some countershaft sprockets have a little axial play.
i believe so, just rebuilt the engine and noticed the play it had, its a 13 tooth, pretty worn out. What would you recommend as a replacement?
I just went out into my garage and checked my 89 and 85 250s they have no play, my set up is sprocket, washer, and bolt. torqued to spec.
Thanks for the feedback, i read on another forum that the tapered shape of the washer can flatten out causing the sprocket to have play in it. I may just need a new tapered washer
I noticed something in between your washer and sprocket, there should be nothing inbetween, is your washer facing correctly? flip it and see how that works.
What youre seeing between the washer and sprocket are the splines of the counter shaft
Looks to me like sprocket is on backwards
I've flipped it around and it had even more slack. I assembled it the way the book said to.
I had an 88 kx-125, all that secured the front sprocket was a clip on the shaft, my 80's cr bikes are solid and don't move, the kx moved a little, your bike is much newer, so they might have changed the specs. But in all honesty, that set up looks like my bikes, so it should just bolt on with no troubles.
Yeah i think im gonna replace the sprocket, bolt and washer, its pretty worn. Any recommendations?
you really should replace both sprockets and the chain.
and unless you are racing go with steel replacements.
Part 3 in that schematic, is it located on the inside of the transmission or on the outside with the sprocket?
Guessing it is not a new sprocket correct?
Front sprocket should not have any play in it, if it does your chain will start to wear the sides of the teeth down significantly, you will notice the link shapes on the sides of the teeth, it happens pretty quickly once it gets loose.
Either your washer needs replaced or the splines on the sprocket are worn and the sprocket needs replaced or worst case scenario the splines on the counter shaft are getting worn and the counter shaft needs replaced.  IME it is typically the sprocket splines.  Just buy a new front sprocket and slap it on there and it will probably be tight like a tiger.
My yz250 front sprockets get loose after a while from the sprocket splines wearing, I started putting red Loctite on the splines when I put a new sprocket on, it is a little tougher getting it back off but I feel I get a little more life out of them.  I think it is not uncommon for the drz400 guys do something similar
Thanks for all the help guys, turns out the bike is missing the countershaft collar that acts as a spacer behing the sprocket
