crf250x won't start
Hi guys n gals, I am hoping some-one can help me in my endeavours to get this bike running. It wouldn't start and I checked the stator resistance and found anomolies with the recommended specs so I sourced a new one and a reg/rec as well. Previously the starter would turn the bike over, no problems except a very low (small) spark. Since putting the new stator and reg on the bike, when I turn it over I get a chattering from the starter solenoid. I took this off the bike and checked it thoroughly, all seemed fine, so I assumed it was getting an ac signal. I emailed the supplier of the stator and reg with readings from all wires, none to earth etc and he says all checks out as ok. In the adr wiring diagram I found a 4 wire ignition board. What that is I don't know but I am assuming I have corrupted something in putting the new stator on the bike. The battery is new. Can anyone help guide me to where the fault may be please.
Hi dankerr, what year is your bike?
What anomalies did you have with your old stater?
You can use a standard multimeter to see if you have DC or AC output.
Do you have spark now?
Can you start it with the kick starter?
Hi Jon, it's a 2008. I had a spark previously but it was very weak, the ohm readings I got from the original stator was very low or nowhere near the recommended specs, so i ordered a new stator and regulator. I have it turning over now but no spark. Kick starting doesn't make any difference. I have found a local that checks stator, coil and cdi on the bench for $90, so I intend to take this to hiim, at least that will give me a direction to go in. If there is something faulty he will source it for me.At least it's a starting place. if all checks out, then I guess I will be checking for incorrect wiring or connections, or shorts? I seem to be playing a waiting game, but all games end right?
Some help is better than no help, I appreciate the input Jon i will follow the thread and let you know what occurs. Yes I have checked the kill switch and the clutch switch, the year of the bike is 2008. Thank again so far.
What stator did you go with wondering if you got the trail tech and made the same mistake that I did and reversed the plugs from stator and regulator
OH!  yes I did get the stator and regulator from trail tech, what wires were reversed?
Did you get the Trail Tech flywheel too? Just curious, I'm in the process of putting the TT Flywheel/stator on my '08 now. The flywheel seems to be protruding out quite a bit from the engine case. I haven't put the stator cover on to see if it rubs - yet. Hoping you or someone else have the same experience.   B)
Edited by jms130
The two 4 pin connectors I mixed them up had to kick the bike over when first started battery was dead but once charged was good to go every time. Just recheck that you have them right
  • Similar Content
    • By Connor Wright
      Hey I have a crf250x 2005 I was riding today in top gear flat out and when I slowed down blue smoke just poured out the exsaughst then I happened to open the air box lid and saw it has what looked like engine oil in it then took out air filter and noticed that there was splatters of engine oil on the inside and that and the channel that goes to the carby had engine oil all over it.
      Also bike got a top end rebuild 15 hours ago
      The engine still runs good and sounds normal
      why would this be happening on a resonabley fresh engine
    • By mikemcbride
      Hey everybody. Quick question for y'all. I recently went riding and about halfway through my ride my motor seized on my '07 CRF250X. I haven't investigated it much but I checked the oil when I got home and there basically was none so I'm assuming that was the culprit. There weren't any metal shavings in the filter or on the plug either. At this point I'm trying to decide to rebuild the motor or just sell the bike as is and let the next buyer deal with it (they would know the deal obviously.) I feel that I'm pretty mechanically inclined but rebuilding a CRF engine is a bit out of my league and I assume paying a shop to do it would put me out more money than the bike is worth. So, I have this question to ask; what would be a fair price for a pretty dang nice shape 07 CRF250X, with a seized motor with an unknown extent of internal damage?
    • By ThomasM.
      selling Hot Cams Valve Shim Kit that i bought for my 2005 crf250x, will also fit crf250r.
      used 1x 1.30 and 2x 1.55 shims. the rest is still there.
      $60usd shipped in the usa or canada
      please contact me for pictures or if you are not sure if it will fit your bike
    • By TerryA
      I have two rides in on my new Rekluse auto clutch and I have to say I'm very pleased. The install wasn't hard, but was pretty much a all afternoon sort of project. I also installed a left hand rear brake kit and a two finger cluth over-ride with the adjuster on the perch (which I rarely seem to need). It has all worked great right from the beginning. After struggling to get up a tricky hill in first gear, I tried it in second and the autoclutch helped me clean the hill easily. Not having to worry about clutch action in techinical sessions has also eased fatigue and just made it more fun all the way around. I ride mountain bikes alot, and having both brakes up on the bars has also been nice as it makes for a set-up just like the bicycle - in fact I like that as much as not having to worry about clutch manipulation. The brake on the bar is especially nice on tricky downhill sections where you need to paddle, such as nasty rock/rut stuff. So first impressions are that it was worth the investment -making the ride more enjoyable and easier at the same time!
    • By Mikey560
      I was driving the bike for 15min or so and all of the sudden the bike stalled. I tried starting it again with no luck. I took the spark plug out to see if there is spark so i ground the spark plug to the frame and there is no spark. I even put a new spark plug in the bike and still nothing. Any ideas what i should check??
