Best Light for Night Riding?
My feedback and my experience is that if you are going to ride off road at night, you need a helmet mounted light.  The light on your bike only helps a little because it is always pointed where your bike is pointed, whereas a light on your helmet points to where you are looking and is MUCH more helpful.
I use a Serfas brand LED headlight that I mount to my helmet, and it works great.
That looks killer. Was the bracket pricey?
Not to bad, well worth the added cost. I bought the stock bracket and it didn't fit well at all. After sending them pictures,Baja designs excuse was "that's just the way it is".price comes with the light. https://www.motominded.com/collections/frontpage/products/led-bracket-ktm-bdi-light-kit-complete
From the look of the picture there will be gaps around the light? Nothing to keep dirt, mud or water from all the wires behind the mask?
Yea I thought it would be an issue but it's not. The light and connections are waterproof and it has a lifetime warranty.
I got ahold of a used 500 XC-W. The previous owner put a group of rigidindustries LED lights on it. You get their bracket and then get the combination of lights that suit your purpose. On here now is; Top left is the driving light w/ high & low beams. The top right is a spot that also comes on with the high beam. The bottom is another spot hybrid that is on a separate switch.
AB607B27-2A19-487C-8AD0-A243BCA13587_zps
It's also all open behind. I haven't really tore in behind to see the connections but it does light up the night.
  • 2 weeks later...
Post a pic of that light setup at night
