2016 FE501s Exhaust Screen Removal
Just wanted to post a simple how-to on this matter. You'll need a dremel with a cutting wheel, and something to hold the end cap.IMG_7506.JPG
I started by cutting vertically through the first screen as far as I could go without cutting into the end cap housing. (Even though I nicked the outside a tiny bit) IMG_7507.JPG
Once I got through it, I used a flat head to pry both sides up a bit, causing the screen to slightly ovalize.IMG_7508.JPG
Then I pry'd underneath the now raised edges and popped the screen out.IMG_7509.JPG
This allowed the inner secondary screen to come falling out with it.IMG_7510.JPG
Start to finish, maybe 10 minutes. Very easy and adds a decent amount of grunt to the bike.
Hope this helps!
