Kx125 clutch help
Hi everyone. While working on my kx125 I start to go ride it, and I notice that when it is in neutral, I hold in the clutch and put it in first, it dies. And it acts like the clutch is not engaging. I have to have it revved up to have it act like its in neutral. If I try to let it idle, it does and rolls a little bit. I've backed out the nut and the cable seems tight. And pulls tight on the engine. I'm just confused on why it is doing this. Any help would be great
Does your basket or hub have notches where the disk and plates tabs rest. If there are this could cause the clutch to pull.
