Cheap battery.
I have a cheapo battery that I had to mix in the acid to and close up. I have it on a trickle charger. How long should I leave it on there to try and max the batteries life??
Depends on the size of the battery and the trickle charger. Hopefully your trickle charger is an automatic charger, and shuts off when fully charged. If so you just let it go until it's fully charged.
Just because you have to fill the battery doesn't mean it's a bad battery. Used to be many AGM powersports batteries you still filled. As much as a DRZ vibrates, and gets leaned, I wouldn't put a coventional battery in it, but if the battery you got was an AGM you'll be good to go.
Bike is an 09. I bought it new in 11. I used to ride every day as my commuter but I can no longer do that so I put it up for the winter. This is the first battery I have put in as the stocker was totally shot.
Indefinitely. ;)
Keep the receipt for that battery because I can almost guarantee that it'll be dead and useless in less than a year.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
