Valve cover breather hose
On a 2010 crf 250r fuel injected bike where does the breather hose go that comes from the valve cover
just guessing here, (well im pretty sure by memory)
but should go into a t-piece one hose goes to the airbox and another down to the bottom of your shock and should have a drain plug on it
Edited by nks0
oh well my buddy just bought a 2010 crf 250r and it's missing the hose and he said it blows oil out
sounds less than ideal.
 how much oil?
I'm not sure exactly
id make sure he hasn't overfilled the engine oil
if no problem there
id change piston n rings
That is a crank case breather. It runs down into the case above the transmission and runs into the air box and it runs into that clear tube right above the front sprocket guard. Make sure you drain what ever is in there after every wash, or muddy trail day.
It runs down into the case above the transmission...
The crankcase breather does not go into the case above the transmission. The transmission has its own separate breather hose, which comes off the top of the case and is routed out the bottom of the frame next to the rear shock. The crankcase breather hose coming off the valve cover leads to a Tee fitting, with a suction hose leading to the airbox and a pink translucent drain hose that secures to the left side of the swing arm.
Edited by mossman77
Whats the reasoning behind the tube going to the airbox? Ive read on here and several other places you can disconnect it and just run one tube down with no plug.
Because the airbox provides suction and it is filtered. The block off kits you see omit the drain and put a filter on the end of the vent tube to prevent dirt, dust, etc from getting sucked into the head. I recently installed a vent kit on my 250X and chose to retain the drain hose. This required using my own tee fitting because the hoses are different sizes. I have 49 tee fittings leftover if you want one (minimum order was box of 50). Otherwise, you vent and drain through the provided filter. I didn't like that idea which is why I chose to mostly retain the stock setup, only with an external filter in place of the airbox.
I couldnt edit the post but I should have said I disconnected the air box from the line years ago in there. I do have a filter on the end of the line, but its just out of the valve cover and straight down. I always wondered about the suction because arent you always going to have pressure from the crank case? If I take the filter off you can see air blow out of the tube.
Edited by CRFRida1605
I don't know for certain, but the filter is there for a reason. Maybe there are certain conditions when the case is under negative pressure. Or when your bike isn't running, you wouldn't want an open tube leading into the heart of your bike. The tranny vent doesn't have a filter on it though, so there goes that logic.
Edited by mossman77
The hose coming out of the cylinder head cover? That's this crankcase breather hose.
That is the one were talking about.
ah i see my errors - its setup different than the bike i have now (450x) i don't have my 09crf250r anymore
yeah the other one is the tranny breather.
i wouldn't call the valve cover breather a crankcase breather but thats just me.
Edited by nks0
All valve cover breathers are crankcase breathers.
The crankcase vents through the valve cover where the timing chain passes, hence the name crankcase vent. The valve cover doesn't need venting.
  • Similar Content
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By ThomasM.
      selling Hot Cams Valve Shim Kit that i bought for my 2005 crf250x, will also fit crf250r.
      used 1x 1.30 and 2x 1.55 shims. the rest is still there.
      $60usd shipped in the usa or canada
      please contact me for pictures or if you are not sure if it will fit your bike
    • By DirtRider250x
      Hi all,
      My main question is how can I make my 250r more reliable. I have owned it for 2 years and it was spent about 1 year in the shed probably needing new valves and piston rings (i have been putting it off) Will steel valves last longer and work well in the engine? Also, what are your thoughts of me selling it and buying something newer? is it worth it?
    • By Throttlejockey
      Please post pics only. All other posts will be deleted so it doesn't get out of hand. PM the poster for more info or create a post.
      Violators will get a one day ban from the forum.
    • By bull413
      I checked the valve clearance on my 06 crf250r and both exhaust valves is at .007 and the intake is (left side) .005 and (right side) .000??? idk my feeler gague only went down to .002 and it would not slide in.
      Is that ok for the exhaust? Do I need to just shim the right side on the intake? or does both need shimming?
