rear tire 140/80-18
looking for a new rear tire for my EXC 500. The rear tire that came stock is 140/80-18. What other size tires will fit? looking for both metric and standard tire sizes that will fit.
Does anybody have a recommendation for a good DOT certified tire that will fit. looking for something with lots of traction in any type of soil and that wears out pretty slow. I mostly ride dirt (95%) and occasionally ride street (5%).
Edited by Lovemydog
Kenda trak master II K760 120/100-18 sounds like the tire you are looking for. I have one on my 350excf I have been extremely happy with it
I have a 500 XC-W. I purchased the MotoZ tractionator I/T. 110/100-18. However, I don't have any real seat time with this tire yet so I really can't tell you how good it is. Just going by reviews I've read and looks... A 140 seems big. Even on my 690 I went down to a 130. The reviews I've read said that the 140 is flatter, better for the street and the 120s or 130s have more of a roundness to it, better for off road and leaning.
What year is your bike? My 2014 bike came with the DOT maxxis endurpro.  I switched that out for the DOT metzler six days and it seems like it has better off road traction and wears about the same.  I ride about the same mix of terrain, probably 90% dirt.
Edited by PTECH
Holy smokes...
Its a 2016. So these are probably quite ridiculous questions. But I would like to clarify this so I understand. Will any tire size fit as long as its an 18? Does the rim width have to match up with the tire width? Are all 18 inch rims the same width and its just the tires that are different widths?
Yes there are different 18" rim widths.  Yours should be a 2.15 which is very common.  110,120,130,140 or 4.60-5.30 tires are typical sizes for that rim.
Is there a way to find out the size other than just calling the dealer? I looked on the side of the rim and I dont see any numbers. Is there a way to measure it when the tires off?
Yep, inside of rim is 2 1/8"
Most 140 tires are about the same width as a 120, I run the Michelin Starcross non DOT on my 500 in a 140 and the width is fine.  Most manufacturers post the tire dimensions so just do a quick size comparison on the brand you want to run before buying it.
Agree. A lot of the 140 tires I've seen have lower profile tread and the 120's have deep tread. So they are about the same. 140 is better on the road though for me. The lower profile tread is stiffer. Edited by Deepseadan
  • Similar Content
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
    • By Brawg
      SO, for information sake and to power the search engines with some key words that i couldn't seem to trigger during my research...I'm posting my desmog process on my new 500exc. Being a new bike...i wanted to make sure that all of my "doings" were going to keep the short excuse for a warranty in tact. I have part numbers for the plugs, washers etc as well as what all came off of the bike. I know it's a simple process for some, not so for others and would like to give credit to the writeup for some great info.
      Long story short...i plugged the hole left from the smog pump thingy on the right side of the cylinder, the Secondary Air System (SAS), the overflow canister, and all the hoses/wires that go with. The electrical plug that was involved I simply taped up with grease in it and strapped it to the inside of the frame rail.
      After i took all of it off, it would not idle....i turned up the idle adjuster (to the left) or counter clockwise in order to increase the idle speed.
      Result!!!!!! NO popping on decal, no stalling after hard accelerating, etc. Sometimes after much creeping and low rpm riding it will load up and flame out. I plan to try a different map after i install my exhaust. I think a new map will be able to add some rev to the top end. Right now it seems kind've flat once you pull through the sweet bottom and mid ranges. The bottom end power of this bike coupled with the silky smooth clutch action makes for the easiest and best suited off road bike i've ever been on. It does what i need it to do!
