KX 65 rearbrake pedal bolt and threads
Just installed a rekluse clutch on my sons 2012 kx 65. When putting on the rear brake pedal I can't seem to get the bolt to thread into the threads on  the frame.
Can anyone tell me what the best way to go about fixing this is? And the the thread specification so I can re-tap it if I need to?
Thanks in advance.
Try threading it without the pedal to make sure it's the right bolt. Maybe you are going in at an angle and the threads aren't catching?
Thanks, but i tried that.
So does it go in without the brake pedal in place?
If yes, then you are not getting it aligned 100% with the pedal on. This is easy to do and it only has to be off a hair to not get the threads started. Or you may have something assembled wrong not allowing the bolt threads to actually catch because the pedal is moved to far out.
If no, then the threads are could be bad on either the bolt or the threaded hole. This can be the result of someone trying to force it while it was misaligned.
Rocky Mountain says it is an 8mm bolt in the OEM parts fiche.
92151 92151-1572 BOLT,BRAKE PEDAL,8MM $14.55
6 In-Stock
If you need to re-tap, take the bolt to the hardware store, and find the correct metric nut that screws onto it. On the bolt bin it will tell you the correct size and pitch. Then you can grab a helicoil set. If the threads are stripped out, you will likely need a Helicoil over just re-tapping it. Helicoil's are pretty sweet and not bad to buy a kit that fits the bike and keep it in the tool box. I just had to helicoil 2 of the threaded holes for my fork guards.
When I get home I can check and see what size my Helicoil kit is. It is for all my motorcycle 8mm bolts. My guess is it is probably the same.
Edited by freeriders98
Thanks for the response. It doesn't go in with out the pedal. the threads on the bolt seem fine.
I can see threads in the hole so I think I'm going to try to re-tap it first. if that doesn't work I'll have to try the helicoil.
Yeah the threads may just be buggered up some, and you can re-cut/clean them up.
re-tapped threads and it went right in. He rode it for the first time this weekend.
Thanks for the help.
  • Similar Content
    • By Tedstrom
      Alright so I just rebuilt my 2012 kx250f complete rebuild. I put the motor back in the bike get everything hooked up and ready to go it takes a few kicks at first (obviously) but after it starts it sat and idled just fine for a while then it stalled out. Tried to start it again wouldn't start I took the spark plug out of it it looked good I was dark and wet. I cleaned it then put the spark plug back in it it took a few kicks but started right back up again then after a while it stalled out again and now I can't get it to start again!? Any help would be greatly appreciated thank you guys and girls for reading and hopefully for the help!!!
    • By luke8500
      Hi all,
      I have a 2004 Kawasaki kx250 that died suddenly on me the other day. all i can get it to do is backfire every once in awhile. Tested the resistance and everything of the magneto and stator with a multi-meter and all is good.  Coil is new oem Kawasaki the reeds are brand new vforce and the top end and carb have been completely rebuilt.  key on crank is intact and all the timing marks are lined up. I hooked a timing light to it and spun the motor over really fast and found that it is sparking way to late.  The service manual says that it is supposed to fire 14 degrees before TDC but it is sparking way after TDC.  Im thinking its a fried CDI box since its the only thing i wasnt able to check.  Any help would be appreciated
    • By luke8500
      Hi all,
      I have a 2004 kx 250 2 stroke and it wont start.  it only backfires.  I was out riding it one day and came up to a stop so the bike was just idling and it started to try and die so i revved it up a few times then let it die and now it wont start back up.  It only pops or backfires when you kick it.  Its getting good spark and i just put a brand new plug and coil in it. I took the reeds apart and they look like they're brand new.  It was running great before so i dont know what happened.  Im thinking it could be a fuel problem even tho the plug is a little wet if you take it out after a bunch of kicking.  Any help would be greatly appreciated
    • By Zach121
      Alright, found three bikes all located where i live in Texas. I know they're all very different, but if you could tell me what you think each bike is worth, and which one would be the best deal. Thanks.
      Notes: Both 2 strokes have new top ends. I think the front brake lever is broken on the kawasaki.
      KX250 2002 $800-$1000?
      YZ125 2000 $1250
      KTM 400SX 2002 $1200
    • By Ryan Turner
      So I'm at a bit of a cross roads, I currently own a 06 rm250 and I love it. I also have a 02 kx250 which I'm selling with intent to buy a newer two stroke. I can't afford a newer ktm and the older ones aren't that great and kawasaki never impressed me. so I'm stuck between 06 yz250 and 05 cr250. I've heard the yz and rm after 06 are almost the same bike just the Suzuki handles better and the Yamaha has better suspension. So I'm not sure if I wanna buy carbon copy of my bike with slight differences. That's why I'm interested in a cr250 I heard the 02+ models RC valves are shit garbage but was mostly fixed in the 05-07 models. I ride at a track and at some bogs down the road from me. So from people who have owned both, what would you recommend. I know the cr is known for a hard hitting power band which I enjoy since im an aggressive rider. Should i just see which deal comes my way first.
