yz85 clutch lever hard to pull?
So i got a new bike and its an 08 yz85 and it has barely been used and starts first kick. but my problem is that the clutch is very hard to pull back and yes i did change the line and the levver but still same problem. at this point I have to use all of my fingers and my wrist starts to hurt after a short time. I need some help!!!
Pressure plate bolts may be over torqued or they might have the wrong springs in there. Also check the actuator arm. There is a bearing inside there and however it is pretty unusual it could be seized up. Check this by taking the pressure plate off and disconnect the cable the the arm and see how freely the arm moves. There should be no tension or stress on it at all it should spin freely.
