Crack in the brake caliper fork clamp
Anyone seen this before
2004 S model, with 52K miles
Not really had a hardlife as most of the miles have been on the road as I use it as winter commuter- yes its done some off road stuff but its not as thought I've been landing 30ft double jumps on it
Can you see it?
close up
After a bit of a clean up with a wire brush
I'd be replacing that ASAP.
Oh yes, got some spare forks that'll be going on asap.
I'm kind of wondering if salt has got down behind it and corroded it and its been expanded by that white crud that forms when sslt solution is in contact with aluminium as its in a strange place to fail there
possible .. i wonder if water trapped behind it and frozen could maybe do it to ..
I don't think it was from water/ salt; I would think it would be more corroded. I'm no metal allergist though.
Keep your ass safe and replace it!
Guy - I think you are exactly right.  I think if that lower part were to be cut off you would find corrosion behind it.  I am a metallurgist but it is still only a guess.
... I am a metallurgist but it is still only a guess.
Glad to see you're allergy free.
update 10 months on
the crack has got bigger
Almost certain now that its road salt solution getting down behind the Aluminium bracket and the fork slider causing corrosion, which is pushing the two components apart with the result the brake caliper bracket is cracking from the stress
This is the gap between the fork slider and the bracket - plenty of gap for salty water to to get in there
and this is the other side with no gap
Forks are off now as that crack was getting too big for comfort
Edited by GuyGraham
