2001 CR250 Jetting
I"m new to the forum. Picked up a really clean 01 cr250 a few months back and I love it. Was always my dream bike growing up. All my friends are living in the 4 stroke world and I'm a 2 stroker forever! Anyways the bike already came with a boyesen rad valve installed, and I recently put on a fmf gnarly pipe and shorty silencer. Took my carb apart to see where my jetting was at and it's set up as follows:
Main: 430
Pilot: 30
Needle 6BEH1-75
Clip Position: 2nd from top
Not sure on the air fuel i forgot to check
I know there have been countless discussions about tuning the mikuni's on the 01's and correct jetting depends on a lot of variables. My question would be does any have a similar set up as me and what are you running? Also is the JD kit worth while for this bike? I've also just bought individual jets so I'm hesitant to buy the kit if I don't have to. This is my first experience with a 2stroke carb though. Any help or discussion would be greatly appreciated.
Thank you,
Using a 36:1 mixture
Dan, I don't own a CR250, or anything with a Mikuni anymore, but check this out and use it to help you learn your carb: http://users.conwaycorp.net/virtus/page2/speed/jetting.htm
There is also "Is my two stroke running rich" in the Yamaha two stroke forum stickies. It contains some of the same info, and a bit more.
You can find a starting point for jetting on the FMF website, but it is only a starting point; every bike is different.
I personally wouldn't buy the JD kit, as I feel like you pay $75 for two needles, if you already have the other jets on hand. I'm sure he earned it through R&D, though.
Some people swap the Mikuni carbs on these bikes for a Keihin PWK.
Congrats on the new bike! Welcome to the forum and to the joy of two strokes.
  • Similar Content
    • By Sammy_1101
      Hi Guys,
      So I recently bought a 1997 XR400. I've done some research into getting more power through some basic mods and rejetting the carbs. Though all of the ones I've found have been for post 98 XR400s so the stock carb set up is a lot different. Usually people are opening up the airbox, exhaust ect. ect. and Jetting their carbs up to 160/162 for mains around 60 ish (I think) for the pilot. However for the 97 model this is close to stock for the jets.
      So essentially what Im asking (Just to cut to the chase ) Has anyone got a 96/97 (maybe 98, not sure) XR400 and has done these similar mods, and what sort of jetting have to done as a result.
      Thanks in advanced, also its my first post so apologies if I havent done everything correctly.
    • By Jturn
      38MM Cast SmartCarb. Purchased a couple years ago for a yz250. Don't have the bike anymore, and it has been sitting around for about a year. Used, but in fine working condition. You can also purchase a different needle for different bikes, as well as rebuild kits from their website.
      Asking $250 shipped to continental United States. I can arrange other shipping options at the buyers expense.
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By knotduke08
      I know this topic has been discussed in the past, but I have not found any options available for the new 2018 bikes. I live and work for a new Beta Dealer (Auburn Extreme Powersports) in California, and we are having a difficult time mapping the RR-S bikes for full FMF exhausts. We have tried contacting Beta Support several times for this issue to no avail, and we typically are given the runaround when transferring to techs and secretaries. From what we can gather, the FMF flash is designed for the RR bikes, but not the street-legal counterparts. Every time we try to install the FMF map onto an RR-S errors occur, and the programmer screen goes virtually blank. We have heard through the grapevine that some are using the RR maps on the RR-S with success, but we have yet to try it, even on our own bikes for fear that it will permanently erase or damage the CDI. Any and all help or suggestions regarding this topic would surely be appreciated! Thanks, Ben.
