WP Cone Valve Forks — Mid Valve stack advice?
I'm seeking a mid-valve shim stack to use with my WP Performance IFP Kit (Base Valve). Does anyone have the shim stack spec's from a Cone Valve style fork that has been modified back to a mid-valve stack for MX? I would love to have a default starting point to use in place of the existing mid-valve stack that came with my CC Forks to complete my WP CC Bladder fork conversion to a cone valve style setup.
Older style Factory (is the same as cone valve fork, without cone valve) fork using the stack:
8x20x0,1
8x20x0,1
8x18x0,1
8x16x0,1
8x14x0,1
8x12x0,1
6x9x0,2
6x9x0,2
Float 0,2 mm
Edited by demzsolt
8x20x0,1
8x20x0,1
8x18x0,1
8x16x0,1
8x14x0,1
8x12x0,1
6x9x0,2
6x9x0,2
Float 0,2 mm
So that was the Stock valving on the generation of cone valve forks prior to the cone valve? What year?
I'm going to measure my current stock mid-valve shim stack and see if anyone has some ideas on which direction to go with.
I do not know the fork year. Stickers on the forks Lippolis Suspension, maybe revalved..
10-4, thanks for the spec's anyway. I'm going to try document mid-valve stacks and see where it leads me.
See the pictures..
Standard 48mm tubes, yes?
Edited by tk2stroke
Standard 58mm tubes, yes?
Fork legs 48mm, not 58..
Notice how soft that mid stack is
Here's a 2010 sxf450
MID
20x0.10*6
18x0.10*3
16x0.10*2
10x0.20
8x0.30
MID
20x0.10*6
18x0.10*3
16x0.10*2
10x0.20
8x0.30
Is this from a WP CC fork?
