Ktm 200 fly wheel side o ring
Hi guys , just finishing up a rebuild on wifes 200 and just wondering should there be an oring and a seal on the stator/ flywheel side of crank ?
No, the crank seal is in the case.
thanks markit ,
i may have worded that wrong
is there only a crank seal or is there a o ring as well like on the primary gear side where there is a crank seal and an o ring on the collar
cant seem to find info in the manual i have
No, the drive side has a bushing on the shaft hence the need for the O ring. No need for a O ring on the ig side as the seal seals directly to the shaft.
Edited by markit
