Yet another battery upgrade thread
Since my battery was half dead I have decided I will upgrade the battery to a stronger + larger capacity unit
Please bear in mind that this is more suited for adventure type riding, rather than hardcore enduro where you want to save weight, rather than adding more.
I know about the battery mod as per Eddie, it is nice too, but the cost of the battery is nearly double.
Stock battery:
Specification
  • Manufacturer: Yuasa
  • Battery Type Number: Yuasa YT7B-BS
  • Battery Type: Sealed 12V AGM maintenance-free battery
  • Filling Kit Included: Yes
  • Dimensions: 150mm x 65mm x 93mm
  • Capacity Rating: 6.5Ah
  • Cold-Start Performance CCA (EN): 85A
  • Maximum Charging Rate: 1.0 Amp
  • Weight (filled): 2.70kg
New battery
Specification
  • Battery Type Number: Yuasa YT12B-BS
  • Dimensions: 150mm x 69mm x 130mm
  • Capacity Rating: 10Ah
  • Cold-Start Performance CCA (EN): 210A
  • Weight (filled): 4.1kg
Please note weight difference is 1.4kg + some weight for box mod.
The battery box only needs to be extended downwards in order to house a new battery, please see photos of how I made this:
You will probably get without rebuilding the plastic, but I did since I had time, otherwise basic tools, 4mm drill, rivets, angle brackets.
I will post pics of how the battery sits in place soon.
