Loose cam tower
The cam tower bolts were backed out. 1 extensively others a couple turns. I assume someone shimmed valves and did not either relighted/Tourque or they need locktite?
They shouldn't need Loctite, unless something is wrong with the threads.
options, retry tightening , get new bolts or Loctite.  the torque on those is fairly light
Use a good torque wrench. Be sure to get one appropriately sized. You want the torque to be towards the middle or high end of the wrench scale, so you're going to need a small one.
