Ohlins RMZ450 to RMZ250 advise
Hello everyone.
Right so i have just bought a rear ohlins shock from an RMZ450 (Ohlins No. SU-15940) to put on my 2012 RMZ250.
Guess what i’m after is a bit of reassurance and guidance as i have zero experience with these shocks.
Got a bit of info from Kais (uk suspension tuner) over the phone.
Valving.  He compared the two stacks between what Ohlins specify for the 450/250 units and suggested i try the 450 shock first and just play with the clickers.
Stock settings:
High Speed - 2
Slow Speed - 12
Rebound - 25
Then go up to 4 lighter on the slow speed compression & up to 4 lighter/faster on the rebound.
Springs.  Might be a bit funny as apparently ohlins go up in two step increments?  I'm currently running a 5.1 105mm race / 35or36mm free....and Kais suggested i go with a 5.0 so that’s what I’ve ordered to try out.  I weight 72kg in street clothes.
Springs are not that close on rating to trust 0.1
Your Sag isn't bad.
I wouldn't change the spring.
Your Sag isn't bad.
current spring isn't compatible with the new shock i am afraid
I run my fox shock from my rmz450 on my rmz250 and my rm250. I have to open up the clickers more on the rmz250 and for some reason it's softer in the rm250 than it is on the rmz250. I run one spring rate less than from the rmz450. I know it's not an ohlins but figured my experience may help.
Thats actually quite handy.  Thanks for your input AC.
Here's one for you:
- Stock shock.  5.1 spring. 105 race sag.  Around 35mm free sag.
- Ohlins shock.  5.0 spring. 105 race sag.  I'm getting close to 50mm of free sag...?
One is wrong and I'm guessing the ohlins
Bet it's the swingarm length.  I was surprised how long that arm was on my RM250.
Cheers mog, you always help with my reassurance questions.
i don't usually do this....but....how rude are Kais (guys i bought my ohlins shock spring from)?! Will not be using them again.  Very abrasive.
I explained my case.  Immediately shot down "you're wrong!".  Nothing more to add.  No back up as to maybe why or anything......ok then.  Then started picking holes in me, my knowledge and my bike.  Said i shouldn't be running 105mm race sag "what are you thinking it should be 95 to 100mm".  Then said i need a heavier spring.  From my experience and understanding would make the free sag greater.  Said the spring i have is no good to them anymore.  Presumably because I've installed it.  I then suggested that maybe the spring was miss tested or labeled.  Could be an honest mistake right?  This then pissed them off even more for some reason.
We argued the toss for a few mins. with no real conclusion.....going to try Dale at RG3 London now; starting off by testing the rate of the spring supplied by Kais and going from there.
It may be that i need a 4.8?  I only bought the 5.0 from Kais's recommendations.
What do you think Mog?
Speak to Karl Anderson kas he will treat you right
  • Similar Content
    • By brownktm19
      Enduro Engineering shock spring 35-084 -- Rate: 8.4  Color: Orange -- $50, free shipping to cont. US only.
    • By brownktm19
      WP CC fork springs.  Unsure if they are 4.6 or 4.8.  Think 4.6, but not 100% sure.  Could probably identify by the number on the spring.  $30, free shipping to cont. US only.
    • By Whopharded
      So I kind of got my head around compression damping and rebound.  Sag and the physics of what it affects... I'm not quite getting it.
      I was reading an article on my bike and they said "it kicked like a scared pony but reducing the sag corrected it".   First off that seems backwards to me.  Seems like they should have increased the sag.   Second, why wouldn't they have just softened the compression damping instead.
      Well, to the bottom line... Can somebody please tell me how the bike should behave more/less sag?
      I always thought of sag as the at resting set point for optimized center of travel.
    • By Chris Edwards
      Hey guys, I'm wondering what suspension settings you all are running front and rear?  I have a 2017 crf 250r I'm a 210lb newer rider, my settings are currently set at,
      rear suspension low speed  at 12 clicks
      rear suspension high speed 2 turns
       rebound is 12 clicks.
      Left front fork inner chamber 150psi, outer  chamber 10psi, balance pressure 150psi
      Right front fork compression position 7 clicks, rebound 29 clicks
      Sag is 4"
      Thanks guys
    • By Stillwell Performance
      One of the most common calls we get here at the shop is “how do you recommend I go about tuning my suspension?” Good question! The second most common call is “I started turning clickers on the front/back/bottom/top etc. and now I don’t know what I did, help!” The amount of improvement you can gain from proper suspension setup is significant, if you go about it in the right way.
      Look at it this way: if you are 6ft. tall and get in your truck after your 5 ft. 3in. wife just drove it, the first thing you are going to do is adjust the seat/steering wheel, etc. for your size. The same thing goes for your bike’s suspension-last week we had (3) 2010 bikes in the shop for revalves at the same time. Identical models, one guy was a 150lbs. pro racing MX, the next guy was a “B” level GNCC racer and weighed 220, and the third guy was a 180lbs. trail rider. Same bike, three totally different setups!
      So with that in mind, here is where to start:
      • Grab your owners manual, a computer, clipboard and a scale. You cannot effectively start tuning until you determine if the correct springs (fork and shock) are on the bike for your weight. Put down the double cheeseburger, hop on the scale, and get your weight in street clothes. Add in for your gear, which typically runs between 20-30lbs. You can easily check recommended spring rates by visiting www.racetech.com under their spring rate calculator. Look in your manual (or ask your tuner) and see what rates are on the bike.
      • If you need to change spring rates-do it first. Trust me on this, trying to tune suspension with the wrong rates is not only frustrating, but you will be short changing yourself on the results. On most bikes the shock spring is easily changed, fork springs can be a bit more difficult-get qualified help if you need it.
      • Even if you are familiar with what “clickers” are, take a moment and read your manual. Determine what style of forks you have (closed cartridge or open cartridge), where the compression and rebound clickers are, and check to see if your shock has both a high speed and low speed compression adjustment.
      • Grab the right tools to adjust, load up and go find a typical piece of terrain to test on. By typical I mean your MX track, hare scrambles course or favorite singletrack. You don’t need to ride a 30 mile loop in order to adjust your bike, rather focus on finding a section of track/trail that has all the different types of jumps/bumps/whoops you encounter.
      • OK here is where I will preach a bit-everybody has a buddy or two that claims to “know suspension” and setup. This is YOUR bike, and unless you plan on dragging him around on the back of the seat the end result of your tuning should be focused on what feels good to YOU. Trust the feedback the bike gives you…..
      • SET YOUR RIDER SAG!!!!!!! This is critical to tuning properly. Again, look in your manual or ask your tuning dude.
      • If you do not have an idea of where to set your clickers, put them in the middle of their adjustment range. This is your baseline setting.
      • Gear up and get warmed up. It is important to be loosened up on the bike BEFORE you start tuning, or you run the chance of mis-diagnosing how the bike is feeling (I never start testing until I have at least 15-20 minutes of warmup time on the bike-I always ride stiff initially and sometimes do not get into a groove until then). Some guys can just jump on and pin the damn thing right from the truck. You know who you are, Wattsy……
      • Remember, this is a tuning session not the MXoN. Use you head and ride at a pace UNDER you max speed-there will be plenty of time to “fang it” once you have zeroed in on some good settings.
      • OK-ride and get a good feel for the bike with the clickers in the middle of their range. Now it’s time to really find out what “too soft” and “too hard” means.
      • Take your clickers and turn them all the way out, full soft. Go ride the bike, but take it easy-it will feel ALOT different. Then come back in and turn everything all the way stiff-go ride again, being careful as this will feel totally different again. For guys that have tuned a bit, these two steps might seem pretty basic, but you will be amazed at the difference in how the bike feels. This is especially helpful for guys who are just starting out.
      • Set everything back to baseline. FROM THIS POINT ON YOU WILL ONLY MAKE ONE ADJUSTMENT AT A TIME!!!!!!
      • So now you will want to determine your tuning range. The tuning range is what settings you will use to adjust for different conditions. For example, If you are an MX racer as well as an occasional singletrack rider you will want to use different settings for those conditions.
      • Fork compression is a good place to start. Ride your test section at baseline, then go about 3 clicks softer. The question to ask yourself after each adjustment is: Does it feel BETTER, WORSE, or THE SAME????
      • There are no right and wrong answers, only what you feel. So let's assume that the 3 clicks softer felt better-go 3 more clicks softer each time until it does not feel as good. You have just found the soft end of your fork compression tuning range. Now return to baseline and do the same thing, only this time go stiffer. After you have found the best compression setting, work on rebound. Remember, one adjustment at a time ONLY or you can become confused!!! Do the same testing with your shock. Once you have both comp and rebound individually adjusted, you can fine tune them to work together-just make one adjustment at a time!
      • As a final test, when you have what you would consider your best setup, write it down, then go back and compare that to your initial baseline, riding both setups back to back. Might surprise you…….
      I could go into some advanced tuning topics about the interrelation of compression/rebound, high and low speed comp, tuning for extremes, etc. but we will save that for another newsletter. Take your time, tune by how your bike feels to you and have fun. You will be surprised by how much better you will ride with well adjusted suspension.
      You can learn more at www.stillwellperformance.com
      KEEP IT PINNED!!!!
      Alan Stillwell
