Pw50 running backwards
Hello all
New ish here so please bare with me.
I've just picked up a pw50 none runner (no spark).
I changed
Spark plug
Spark plug cap
Cdi
Stator/magneto (now sparking) none genuine part.....eBay
Started kicking the bike got some good back fires but then she started. Only problem is the engine is running backwards.
I've done lots of searches but the results have not helped me.
I believe it's ignition timing but it's none adjustable?
On one occasion when starting the bike the engine did run forward but did seem abit flat when you revved it.
Any help would be greatly appreciated
Thanks rob
Either the flywheel is installed wrong (not uncommon for the key to pop out during install) or the stator/crank position sensor is installed wrong or is a part not meant for your bike. A risk you take buying Ebay non-oem parts
Compare the old parts you took off to the new ones.  Sounds like the timing is a little bit too far advanced.  Are you starting the bike with the ignition switch in the start position?
I really don't see what the problem is, if your child can ride it backwards they'll be awesome.
  • Like 3
Hi all
1. What is event timing?
2.i did compare all parts and all looked the same. I ended up removing both the coils and the pick up sensor and mounting them on the original Yamaha back plate. The bike did run forwards once but power seemed flat.
3. Yes I'm starting the bike with the switch in the start position
4. Before letting my boy ride backwards I dicided I should go first. Bad idea!!!
Thank you for all the replies so for
An interesting thing about 2 strokes is that they can run just as well in either direction. Since there are no valves, the cycles are completely symmetric. I believe the only thing that causes them to have a preference to run in one direction over the other is ignition timing.
I would guess that somehow when you replaced the stator coil something happened to significantly retarded the timing past TDC so that the engine prefers to run the other direction.
The PW50 doesn't have a clutch. But if it did, I bet you could pop start it in the direction of your choice.
EDIT: Can the coils be installed backwards?
Edited by rjpjnk
It does sound like timing, but I have gotten burned on aftermarket electronics in the past. One of the non oem parts could be defective. Check out ski doos r.e.r. Concept if you get a chance, the engine runs normally for forward direction and when you press the reverse button the engine slows down to almost a stop and starts back up spinning in the opposite direction. That is all controlled through the Ecm.
Hi all.
Done some more work tonight.
1. I slotted the holes in the stator plate so I could advance and retard the timing by around 10mm each way
2. I turned the stator around 180 degrees refitted.
3. I swapped both coils around on the stator plate.
None of the above helped and all made the engine run backwards.
Also swapped the cdi. Still no joy???????
I think I will have to try get a genuine stator
Any more ideas anyone
Thanks rob.
That's a great idea. I can't ride backwards but I feel like might only be because I learned going forward. If you start out going backwards it might be just as easy as going forward. When your kid is riding his pw backwards around the beginner track everyone is going to stop what they are doing to watch. Imagine how proud you will be.
Interesting issue.
So does the kick starter turn it forward then on last forward rev it fires into reverse? I presume so. Doesn't that suggest that (in the forward direction) it has excessive spark advance?
When you removed the plug to check spark did you see just one spark per rev?
Remove the rev limiter box and start it with the switch in run position. Just to see what happens. I always had that box removed.
Also start it without the muffler in case of excessive restriction. Or clean out and drill out the muffler core a bit.
Hi.
Yes when kicking the bike over its turning in the correct direction but just before the engine stops turning it catches and fires in reverse direction
Sorry for being thick but what's the Rev limit box?
Hi all.
Thanks rob.
Is there any chance the flywheel is rotated on the crankshaft due to a sheared key?
Lol its really crazy if this is not a sheared flywheel key.
The irony is they used to have a PW at MMI that ran backwards so that we could troubleshoot the flywheel key shearing issue.
Suppose it could be the flywheel itself...a different year or model or something?
I was riding my old Husky one day pulling ribbon after desert race. I would pull up to a ribbon grab it and stuff it under my shirt.
As I was stuffing a ribbon my bike nearly stalled. I quickly grabbed the throttle and kept it running.
Problem was as I tried to pull away, the bike felt like the back wheel was stuck in a hole. I tried again to take off, but the bike wouldn't move forward.
I looked down a the back wheel as I released the clutch and it was running backwards. I shut it off and restarted it and rode away.
Realized shortly after that my rod bearing was so loose it was letting the piston dwell at top dead center to long and it could fire backwards at low rpm's.
Not saying that's your problem, but it is a possibility.
