Ktm 530 broken gear lever, screw stuck inside gear shaft thread
So my gear lever broke off earlier today when I shifted into neutral. Thankfully it was just as I was putting my bike away, and not when I was out riding.
The issue I have is that the screw had snapped, so half of the screw is inside the gear shaft (I think that's what it's called) where the gear lever is attached and the other half has obviously broken off.
My concern is how I'm going to get this screw out? I don't want to open the engine up to replace the shaft, because quite frankly I don't have the practical experience of doing so and I'm not comfortable with doing it quite yet.
Secondly, I don't have money to play with right now so I can't afford to pay somebody who is more mechanically competent to do it for me.
I was suggested to either use a dremel tool to drill a small hole in the centre of the screw, and then fit a small piece of metal in that slot and slowly twist it out with some pliers; or, I could have the gear lever welded onto the shaft.
I'm not sure how well the first option would work, and I'm concerned about welding the shifter onto the shaft, because I won't be able to take it off if I ever need to (give me some scenarios where I'd have to remove my gear lever?)
Does anybody have any ideas or recommendations about this? I've attached a few pictures if it helps:
I would suggest drilling a hole in the bolt & using a Easy Out of the correct size to remove the broken piece. Prior to attempting to remove it though I would give it a thorough soaking of WD40 for 24 hours. This is what an Easy Out looks like. Cheers & good luck.ImageUploadedByThumper Talk1461281216.329536.jpg
Welding the lever to the shaft is a terrible idea.  The heat from the welding will likely damage the shaft seal and you won't have any way of replacing it.
EZ-Outs are fine tools for this operation but the trick is getting your hole drilled precisely enough in the center of the broken screw.  The end of the broken bolt is uneven so it's difficult to get a drill to start on center and not drift off to one side.  If your hole drifts too much to the point where it intersects with the threads in the shift shaft hole, it will lock them together and make it almost impossible to remove the broken screw.  About the largest hole you will want to drill is about 1/8" diameter.  MAKE SURE that you don't break the drill or the EZ-Out off in the hole or you might as well throw the shaft away.
I'm not sure if the shaft can be removed from the engine by removing the RH side cover and maybe the clutch basket but if it can then that is the best way to get a good job done when trying to remove the broken screw.  Once the shaft is removed it can easily be fixtured on a mill, an accurate hole can be drilled and an EZ-Out  (or my favorite trick is to use a LH drill bit).  You will need to heat the shaft a bit before you try to remove the screw with the EZ-Out to soften the Loctite that should be on the screw.  Your other option at this point would be to simply buy a new shaft but that will probably be a lot more expensive than having the bolt removed.
If you don't have confidence that you can drill the hole properly it would be best to take the bike to someone who can.
Welding isn't an option anyway as the shaft is steel and lever is aluminum.
Edited by exIT
Use reverse drill bits, so that as you drill the hole, the broken stud might unscrew out. Will need to get some heat on the shaft to loosen the Loctite.
If you can't get the broken bolt end out, it's a $70 part plus the $27 clutchcover gasket
I was noticing there is like 3 washers in between the bolt and the shaft (oem).   Did this aftermarket shifter have any relation in snapping the bolt head?
Edited by Spud786
Hi all, thanks for the replies. The drill method seems to be the way to go in this case then; but this is a real pain in the arse. I'll take a look at those EZ out tools to see if they can get the job done.
Other than that; If I have to replace the shaft, is there any way of knowing if I can do it through the clutch basket without actually doing it? Do you think that kind of information would be in the manual or would I need help from somebody who knows the ins & outs of this model of bike?
Thanks for the info anyway guys, if I get it out I'll update the thread and let you know what I did to remove it.
Thats sucks have been there but not this application, anyway the key to easy out is heat expands the metal and should come right out
It's easy to replace the shift shaft. Remove the clutch cover ( the inner not the outer cover). The gasket will most likely tear when removed so order a replacement at the same time. The shaft should slide right out.
Thanks for the comment, I'll keep that in mind if I ever need to in the future. For now though, I've manage to sort it out :-)
I drilled a small hole in the center of the screw with a dremel tool. I then went and bought some screw extractor screws (i think they are the same as EZ outs) from screwfix for £3.99.
I put one of the screw extractors into the center hole of the screw and used a drill to rotate it counter clockwise. The screw came right out, so I'm very pleased about that.
I have to note though, that this method isn't working on some other screws that are stuck in my bashplate, so it seems quite temperamental. I'm just happy it worked this time :)
I've attached some pictures of the little bugger
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
