choke raise idle for 10 sec only
Hi
bike starts good cold or hot ,but when i use choke on cold engine, idle raise for about 10 sec and drops to 1580 rpm . I also can not set idle more than 1580 rpm or it will hang . From 1580 to 1640 rpm a slight blip from throttle will bring it back down . any setting over that it will hang bad and high . i had this problem for over 6 month so i have tried everything i have read here on TT from 2002 to 2016 , twice .
fcr 39 mx
blue needle jd jetting 2 clip from top or red 4 clip same problem
45 46 48 or 50 pilot same problem
no pilot air jet
165 main
fuel screw i.5 to 2.5 turns depending on temp (between 40 f  and 70 f  )
just changed slide seal
just changed cable
120% not mechanical or air  leak
i do have a lot  off carbon residue on spark arrester
very bad fuel consumption
beside all that , bike runs fantastic from low to high RPM
i just would love to have my idlle set to 1800 rpm ( lot off slow single track riding )
Any  ideas are more than welcome .
