'89 yz80 kick starting issue
The kick starter has lost some resistance through the starting motion, best way to describe is a loose feeling past the halfway point.It won't kick start but can bump start. The motor has compression when it kicked over in the middle of the motion.
The bike had a top end by the previous owner in January. My shotgun mechanic mind thought new top end or rings. Once I broke it down every thing up top was in perfect shape along with rod and crank.I put new rings in since I had it apart.
The bike ran great and had proper maintenance in my ownership.
I'm thinking one of the kick starter springs is bad causing the lack of resistance,?
Thoughts?
run a compression tester on it.
the spring is not there to add resistance to the kick starter, its job is to bring the lever back up.
Update, I went over all my work and retorqued the top end a d reset all the factory carb settings put another new plug in and it fired first kick?
The kick starter stills feels soft, but I can't complain that it fires on first kick.
I will take it for a spin today to see how it runs?
It ran great popped a wheelie out of second. I will run a compression test.
If it is within spec I will chalk it up as one of those 2 stroke anamolies.
