Researching plastic ideas.
I currently have a 2001 YZ250. I wanted to freshen it up a bit. I think that everything looks great besides the Front Fender/Number Plate. I have read some other articles and seen some post about mounting newer plastics models.
I wanted to know if anything has changed recently as far as front fenders/number plate go. I also want to know in your opinion what is the best year to get a fender/number plate from. I was thinking of mounting the 2015 YZ250X or YZ450F fronts on my mine. However I'm not sure what modifications I would need to do to get them to mount on. I hope the holes aren't totally different? Pictures too?
You will need to drill holes for fender, and zip-tie plate if you change to the newer models. Otherwise you good up to 2005 I believe for front fender number plate.
  • Similar Content
    • By Rick Mcqueen Art
      A tiny clear rubber tube on bottom of carb.  On bottom sort of on side, by floats, the other end just hanging down.  Was it always like this? Or does the other end go somewhere?  Today after multiple trys with kick, choke on/off ,,,fuel keeps pouring out the tube.  This bike has always been hard to start.   Thanx  guys!
    • By Brock granberg
      I just did my valve adjustments and put my YZ250f back together as far as the valves, shims buckets and cam covers on but I need adhesive for the plastic valve/cam cover and I am stumped as far as what to use and where to get it or even what to call it! Need to get some soon im in need of a ride!
    • By ThatE30GUY
      Hey guys, I bought this YZ85 and came to realise the clutch wasnt working, so I drained the oil (Jet black) and pulled the plates out and cleaned them. I assumed finding a torque wrench would be easier than it has been. Does anyone know how to torque the clutch springs to spec without a wrench? Any insight helps.
